Hi,
http://www.cirrus.com/en/pubs/proDatash ... -39_F3.pdf
I'm thinking about building a board to go into a Marantz cd40 player.
Plan:- tap I2S from Saa7220 input, and use 11.2896MHz low jitter oscilator to feed dac, and saa7310 decoder.
Do you think it will work ?
I'm a bit worried that the clocks won't be in sync.
Even though dac is CMD i think the stage will be easy to build, and potentially low jitter.
Cheers,
Ashley.
Many thanks,
Ashley.
CS4334 board
Hi, Ashley,
have you seen this?:
http://digilander.libero.it/giovannidef ... AC/DAC.htm
SalutiHi,
Cheers,
Ashley.
Many thanks,
Ashley.
Originally posted by ash_dac - 23/03/2006 : 23:24:52
- 873 Visite
- 1103 Visite
Ultimo messaggio da clane
- 51 Risposte
- 8070 Visite
Ultimo messaggio da mrttg
- 9 Risposte
- 4504 Visite
- 1278 Visite
