nooo, che dici mai... qualcuno si ricorda di Mattei?audiofanatic ha scritto:Sembra quasi che a toccare certi interessi si faccia una brutta fine...
Annuncio choc: "Ho realizzato la fusione fredda" !
- Has thanked: 162 times
- Been thanked: 82 times
Re: Annuncio choc: "Ho realizzato la fusione fredda" !
Per il momento, nulla di nuovo...
http://www.theoildrum.com/node/7942
ma questo articolo è interessante: http://arxiv.org/abs/cond-mat/0703715 (segnalato in questo commento). Un altro commento interessante. Ed un altro ancora.
La trasmissione di Giannino su radio24 dedicata all'argomento.
Non ho tempo di ascoltarla ma sentirò lo streaming dopo.
The scientist Brian Ahern wrote a letter to CMSN about a successful experiment similar to the Rossi Ni-H
Re:
Zr-Ni-Cu alloy performance Ames National Laboratory processed metal alloy foils via arc melting followed by melt spinning. This is the Yamaura process employed by Arata and others. The foils were baked in ordinary air at 445C for 28 hours. The brittle, oxidized foils were placed in a tumble mill for 24 hours. This resulted in 30 grams of black powder with a median grain size of about 40 microns.Presumably, each grain has about one million nanoscale islands of NiCu inside. The 30 grams occupies about 7 ml inside the 50 ml dewar. The system was vacuum baked at 220C for 24 hours and cooled to room temperature. H2 gas was added at 200psi. The pressure dropped only to about 185 psi over twenty minutes. In these replication experiments the exothermic reactions have had peak temperatures above 220C with substantial loading above 3.0 H/M ratios. This time the temperature only rose by 2 degrees C. The system was heated with a band heater to high temperature. There was no controller. A rheostat was set at an arbitrary position and the system comes to a an arbitrary temperature.The average power input was 90 watts. After several hours the hydrated system was evacuated overnight at a constant high temperature at 530C. The next day H2 gas was again added at 100psi and the temperature rose by 40C to 570C and came back down to 530C after two hours. At the end of the day the dewar was again evacuated while still at 530C overnight. The third day repeated the same procedure. H2 gas was added at 100psi and the temperature rose by 44C to 574C. However, this time it did not come back to the initial temperature. It remained at the elevated temperature overnight. On the fourth day H2 gas was again added at 100psi and the system rose by 50C to 580C and again stayed at the elevated temperature indefinitely. A rough calibration suggests that the 30 grams of hydrated nanopowder is putting out 5 watts of excess power. Yesterday Peter Gluck suggested that the relationship between loading and excess power may be a myth. This seemed to be true for electrolysis with Pd and heavy water where loading levels exceeding 0.9 D/M were a prerequisite for observing excess power. My loading level with this nanopowder sample as less than 0.1 H/M. This 5 watt excess is very much less than Rossi, but it is a real and repeatable experiment There was no radiation above the background level. Other alloys from Ames NL are expected within ten days.
Celani confirms a "beatiful mail" from Brian Ahern "so beatiful it could not believed".
Re:
http://pesn.com/2011/05/31/9501837_Cold ... ASA_Chief/
Traduzione italiana:
http://22passi.blogspot.com/2011/06/cap ... edito.html
Resa nota la composizione del gruppo di ricerca sull'E-Cat all'Università di Bologna:
http://22passi.blogspot.com/2011/06/elo ... ollia.html
La guerra dei brevetti, fuoco incrociato tra Rossi e Piantelli:
http://22passi.blogspot.com/2011/06/pat ... telli.html
Ora anche Piantelli annuncia una implementazione pratica?
http://22passi.blogspot.com/2011/06/roy ... amore.html
Dal solito blog, la segnalazione di un eccellente servizio sull'argomento:
Low Energy Nuclear Revolution
« Si tratta senz'altro della più completa testimonianza in circolazione sull'argomento, di altissimo livello qualitativo; costruita attorno a video-interviste originali fatte a Sergio Focardi, Emilio del Giudice, Francesco Celani, Christos Stremmenos, Giuseppe Levi, Stefano Bagnasco, David Bianchini, Angelo Saso. »
Dalla parte degli scettici: intervista a Giuseppe Levi su "Query Online" (il forum del CICAP).
Un altro blog dedicato all'E-Cat: http://energycatalyzer.blogspot.com/
ma non era a Luglio che doveva entrare in funzione la centrale in America?
Articolo 12, Comma 21
Articolo 12, Comma 22
Uh? questa mi deve essere sfuggita: io sapevo solo di quella in Grecia prevista per Ottobre.
- Been thanked: 32 times
Resoconto dal convegno: “La fusione fredda è diventata realtà?” – Viareggio, 23 luglio 2011
http://22passi.blogspot.com/2011/07/dir ... eggio.html
Molto, molto interessante. Non perdetevi l'intervento di Celani:
http://22passi.blogspot.com/2011/07/int ... eggio.html
Mancava l' azionariato popolare, adesso c'è: forza, mettete mano al portafoglio....UnixMan ha scritto:Resoconto dal convegno: “La fusione fredda è diventata realtà?” – Viareggio, 23 luglio 2011
Manca poco ad ottobre....quasi quasi non rinnovo il contratto per il teleriscaldamento, avrò anche l' acqua pubblica con la quota vitale gratis, mi trasferirò a Napoli dove ci sarà già il 55% di differenziata reale ( ed il 70% prima di Natale)
Buona serata a voi; vorrei approfondire ma questa sera ho ospite a cena la fata turchina, ed ha richiesto un menu' impegnativo.
di cosa stai parlando?!?MBaudino ha scritto:Mancava l' azionariato popolare, adesso c'è: forza, mettete mano al portafoglio....
Non mi risulta che le aziende che in qualche modo fanno capo a Rossi siano sul mercato azionario.
Viceversa, pare che invece Piantelli abbia avviato una raccolta di finanziamento per il SUO progetto (indipendente):
http://www.energeticambiente.it/sistemi ... telli.html
quindi, secondo te, dopo Rossi e Focardi, adesso anche Piantelli è diventato un truffatore?
E forse lo sono anche Levi, Celani, Del Giudice, Arata e tutti gli altri?
Indubbiamente, dato il suo controverso passato, qualche dubbio su Rossi si può anche averlo. Ma, per quanto mi risulta, tanto Focardi quanto Piantelli sono persone stimate ed integerrime, così come di sicuro lo sono Levi, Celani e Del Giudice.
Per inciso, ricordo che Piantelli in passato ha collaborato con Focardi, ma la collaborazione tra i due è finita prima dell'inizio della collaborazione di questi con Rossi. E che Piantelli non ha mai avuto nulla a che fare con Rossi. Anzi, al momento i due si stanno combattendo l'un contro l'altro armati in una una "patent war" senza esclusione di colpi...
Certo che è Piantelli; non ho mica scritto che era Rossi. Rossi, un paio di mesi fà, chiarì che aveva sufficienti finanziamenti e non cercava altri quattrini.
Ho semplicemente osservato che siamo all' azionariato popolare, ma avrei potuto dire che siamo alla bomba all' afnio, alle tecnologie inventate da Fermi e mantenute segrete dai militari: sono note di colore sul mondo attorno alla fusione fredda.
- 2830 Visite
Ultimo messaggio da drpaolo
- 47 Risposte
- 21604 Visite
Ultimo messaggio da Teslacoil
- 2960 Visite
- 10 Risposte
- 4216 Visite
Ultimo messaggio da riccardo
- 12 Risposte
- 4041 Visite
Ultimo messaggio da Arge
