Beyma 8bx coassiale
Natali
Messaggio da Natali »
Poichè viste le mie immense conoscenze di elettronica sono stato assegnato dalla sezione torinese di audiofaidate a costruire le casse :D , (per il bottom audio del 2011), ho appena comprato su ebay un paio di altoparlanti coassiali Beyma 8bx.
Se qualcuno li conoscesse o avesse suggerimenti, saranno bene accetti, visto che anche con l'acustica non sono molto meglio che con l'elettronica.
Intanto ecco i dati del Beyma:
Specifications
Low Frequency Woofer
Nominal Basket Diameter 8" / 200mm
Impedance 8 ohms
AES Power Rating 100 Watts
Program Power 200 Watts
Frequency Response 25Hz - 8.0kHz
Sensitivity (1W/1m) 92dB
Voice Coil Diameter 1.5" / 38.5mm
Recom. Enclosure Volume .75-2.25 ft3 / 20-60 Liters
Voice Coil Length 14 mm
Air Gap Height 6 mm
X Damage (peak to peak) 20 mm
BL Factor 7.3 N/A
Magnetic Assembly Weight 4.4 lb. / 2 kg.
High Frequency Tweeter
Impedance 8 ohms
Minimum Impedance 6 ohms @ 4kHz
AES Power Rating 20 Watts
Frequency Response 3kHz to 20kHz
Sensitivity (1W/1m) 102dB
Dispersion 90°
Voice Coil Diameter 1" / 25.4mm
Flux Density 1.5 T
BL Factor 4 N/A
X Damage 20mm
Mounting Information
Overall Diameter 8.5" / 216mm
Bolt Circle Diameter 7.9" / 200mm
Baffle Cutout Diameter-
- Front Mount 7.16" / 182mm
- Rear Mount 7.3" / 185mm
No. Of Mounting Holes 4
Volume Displaced By Driver 0.056 ft3 / 1.5 Liters
Overall Depth 4.72" / 120mm
Net Weight 6.39 lb. / 2.9 kg.
Shipping Weight 6.83 lb. / 3.1 kg.
Materials
Low Frequency Woofer:
Basket Die-Cast Aluminum
Cone Polypropylene
Surround Rubber
Voice Coil Aluminum
Magnet Ferrite
High Frequency Tweeter:
Diaphragm Aluminum
Voice Coil Edgewound Aluminum Ribbon
Voice Coil Former Kapton
Thiele-Small Parameters
Resonant Frequency (fs) 52 Hz
Impedance (Re) 5.5 ohms
Coil Inductance (Le) .2 mH
Mechanical Q (Qms) 6.1
Electrical Factor (Qes) .77
Total Q (Qts) .68
Comp. Equivelant Vol. (Vas) .81 ft3 / 23 Liters
Voice Coil Overhang (Xmax) 5.0 mm
Surface Area of Cone (Sd)m2 0.022m2
Reference Efficiency .53%
Displacement Volume (Vd) 110 cm3
Ciao, Andrea
Vabbe' veramente questo è un esperimento (ispirato da Gluca) per provare un altoparlante coassiale (che in generale sono molto, molto cari).
...sono stato assegnato dalla sezione torinese di audiofaidate a costruire le casse :D , (per il bottom audio del 2011),
Originariamente inviato da Natali - 06/07/2007 :  16:01:32
2011? Devo spicciarmi con la mia parte.
Il PDF non si scarica.
Quanto lo hai pagato? ( shhh!!!! .... en racumandu... ca' disa meno dla metà ed lon ca la pagalu verament, dobbiamo essere leali e sportivi; ) )
Natali
Ho tolto il PDF, che non funzionava (boh?) ed ho copiato i dati del woofer.
Comunque ho pagato la coppia 140 euro piu' le spese di spedizione dalla Germania. Vediamo un po' quando arriveranno... il venditore mi ha scritto che sono "used but as new" aperti e richiusi.
Cerea, Andrea
Che tipo di carico pensavi, visto il Qts di 0,68?
Sopporta decorosamente bene l' escursione
Natali
Starei pensando di fare un bass reflex, con volume intorno ai 60 litri. Ora sto facendo un po' di simulazioni. Grazie Mauro per i software.
Ciao, Andrea
Natali
Ecco una foto delle casse in via di completamento. Mancano ancora i condotti reflex, un crossover definitivo ..... comunque suonano.
Ciao, Andrea
Ma dove hai preso quel colore? Se te li carichi li ascoltiamo con i miei amp una sera di queste.
Natali
Vedo che il colore ti è piaciuto molto, beh dal vivo non è così fosforescente. (L'ho preso in un colorificio vicino a casa, è un azzurro standard).
Per ora sono collegati al gainclone, devono rodarsi un po', ieri sera hanno suonato solo musica tranquilla: Afterhours/chi ha paura del buio, Kyuss e Rage Against the Machine. I vicini non hanno chiamato i vigili.
A proposito, sto ampliando la collezione di dischi di Miles Davis, tra gli ultimi acquisti mi piace moltissimo In a silent way.
Per il trasporto si puo' fare.
Ciao Andrea
PS Ho comprato su ebay no.10 6E5P (le sto aspettando) un tetrodo che in russia usano al 90% dei casi come driver delle valvolone (GM70, 845, 211 o anche piu' grosse...) se per caso ne volessi un paio da provare...
Prime impressioni, a caldo?
Natali
Prime impressioni: suonano in maniera piuttosto diversa dai dipoli, hanno un basso piu' marcato e a volte gli alti sono un po' in evidenza, forse è anche perchè ho lasciato il woofer libero ed ho tagliato il tweeter molto in alto , inoltre ho messo poco assorbente all'interno. Vedremo dopo il rodaggio.
Comunque non sono male, a Natalia piacciono molto (meno male).
Ciao, Andrea
Been thanked: 29 times
Ciao, Andrea
Originariamente inviato da Natali - 11/10/2007 : 10:24:45
dato il Qt alto (e per fortuna non hai resistenze in serie a causa della bobina di filtro...) sarebbe il caso di disporre un cuscino di assorbente immediatamente a contatto con il cestello del woofer, mentre nel mobile concentrerei la disposizione agli estremi della colonna
comunque non condivido la scelta di non realizzare un vero e proprio crossover...
un coassiale può diventare realmente una sorgente unica a banda intera solo se le vie sono attentamente incrociate
Natali
Ciao Filippo,
Grazie per i suggerimenti:
- per cuscino di assorbente da posizionare dietro il woofer potrebbe andare bene l'acrilico di un cuscino?
- per il crossover, in effetti penso che avro' parecchio da giocare, per ora ho optato per la soluzione piu' semplice, tanto per sentire come suona l'altoparlante.
Ciao, Andrea
Been thanked: 60 times
Filippo che fai? Aiuti la concorrenza?? :D
Natali
Credo che qualcuno stia tentando di camuffare un paio di La Scala per tentare di vincere il bottom audio. Arbitro!!
A proposito, Piergiorgio, cosa pensi di presentare?
Ciao, Andrea
Andrea, non ti preoccupare. Se Piergiorgio ci boicotta, chiederemo consigli a Filippo Punzo sul forum di AR. :D
Ciao ciao Mauro
Natali
Dopo tre mesi di "tournee" le casse sono tornate a casa, ora ho assemblato un crossover un po' piu' serio e non suonano male, mi sembra (comunque meglio di prima).
Ora le faro' suonare un bel po' e vediamo.
Foto:
Ciao, Andrea
PS: Mauro e Gianluca, non disperate...
Ciao Andrea... finalmente habemus crossover :) ; dietro vedo le preziose piante della moglie ; ) ti sei sincerato quale genere di musica prediligono (Clive Backster le collegava un poligarfo per studiare le loro reazioni)
Natali
Eh Tiziano, la musica è un po' rumorosetta, al ficus stanno già tremando le foglie...vediamo un po' come va la cura primaverile.
Il tuo amico Clive era un mago della comunicazione :D
Ciao, Andrea
Natali
Ecco lo schema del crossover che uso ora, se qualcuno avesse suggerimenti, sono ben graditi, grazie!
drews
Messaggio da drews »
Non è troppo bassa la resistenza da 1,8 ohm in parallelo al tw???
Non tende a "chiudere" troppo in alto il tw???
