Tool per produrre prototipi di PCB con CNC
Has thanked: 145 times
Been thanked: 63 times
tool for engraving PCBs using CNCs; Generate efficient gcode to mill PCBs using voronoi-regions.
Visolate reads the gerber files describing printed circuit boards and converts them into the G-code (RS-274 code) needed to engrave their layout into a board using a CNC machine. Precise renditions of the original layout can be created as well as voronoi fillings of the original layout, shortening the toolpath.
http://sourceforge.net/projects/visolate/
