Inviato: 06 gen 2006, 14:52
con chi farlo "sposare" e in quale "box" farlo andare a vivere?
questi i parametri:
M18WO-09-08
Nominal impedance [ohm] 8 SPECIAL FEATURES:
Voice coil resistance [ohm] 5.7
Nominal power [W] 70 Long stroke, low
Short term max power [W] - reflexion magnesium
Long term max power [W] - basket
Operating power [W] 7.1
Sensitivity [dB] 87.5 Stiff airdried paper
Frequency range [Hz] 35-4000 cone
Free air resonance [Hz] 35
Voice coil diameter [mm] 40 Low damping rubber
Voice coil height [mm] 14 surround
Air gap height [mm] 6
Voice coil inductance [mH] 0.9 Kapton® V.C. former
Eff. diaphragm Area [cm²] 132
Moving mass [g] 17.5 Long throw magnet
Magnet weight [g]/[oz] 698/24.6 system
Force factor [Bl] 7.5
VAS [l] 28.5 Optimized for bass
Qms 6.70 reflex
Qes 0.39
Qts 0.37
saluti a tutti. paride
questi i parametri:
M18WO-09-08
Qms 6.70 reflex
Qes 0.39
Qts 0.37
